My New Buffing Machine http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=32583 |
Author: | Chris Ensor [ Thu Jun 16, 2011 6:15 pm ] |
Post subject: | My New Buffing Machine |
Let me preface this whole thing by saying that while I did get good advice to not mount this thing on a cabinet, I have no wall space and had to mount it to a stand. I will be careful and likely pad the area around the wheels. That being said, here is how I built this thing: Attachment: IMG_5199.jpg These are the parts (in no specific order): 1 threaded rod 30" long 7/8" diameter with a LH thread on one side and a RH thread on the other, 2 LH threaded nuts, 2 RH threaded nuts, 2 spacers w/ 7/8 i.d. and 1/4 o.d. (to convert the rod to fit the wheels), one 1/2 hp motor, 1 switch, a pulley for the motor, a pulley for the rod, a belt to move the thing, 2 pillow block bearings, and 2 sets of flanges. And of course, a couple of buffing wheels, a rake, and some buffing compound (not pictured). I should note that I got the pillow blocks and pulleys before I bought the rod. When I went to purchase the rod, I asked them to make sure it fit inside these items. I didn't plan on having to pay for (or do the labor myself) to thin down the rod. It all fit like a glove. Attachment: IMG_5200.jpg First things first, center the pulley on the rod. By the way, I found a calculator online that allowed me to figure out what size pulleys to buy to reduce the speed from 1725 rpm to 1000 rpm. The rod pulley is a 5"er and the motor pulley is a 3"er. Attachment: IMG_5201.jpg I next put the pillow blocks on and spaced them according to where they would be mounted on the stand I made. I attached the bearings before I put them on the stand so that they would be all kosher and not out of line. I figure if I had tried to mount the bearings to the stand then insert the rod, it would be much harder to get everything aligned just right. Attachment: IMG_5202.jpg I then went on to mounting the assembly to the stand. The legs of this stand are from an old free audio mixing board stand I had laying around. You have one of those too right? ![]() Attachment: IMG_5203.jpg Next, I mounted the motor. I was looking for two things here: 1- that the belt has enough tension on it, and 2- that the pulleys were coplanar with one another. I used a straight edge to do this. Once I had it lined up, I marked for holes, and drilled. I then bolted the thing down, double checking tension and coplanar. Looks good to me. Then, I mounted the switch. Couple of screws and the thing is on. I next did a test and made sure the thing ran without wheels on it yet. Yeppers, it workes. Attachment: IMG_5204.jpg I mounted the wheels, using the spacers and flanges, tightened it all down, and it runs great. I tested it out on a junk body that I keep around to practice new finish technique, and it made it shiny. Imagine that. I just have to be careful I don't bump it.... |
Author: | parrotheadmj [ Thu Jun 16, 2011 8:05 pm ] |
Post subject: | Re: My New Buffing Machine |
Chris, Nice job....looks cool Marc |
Author: | Robbie_McD [ Thu Jun 16, 2011 10:00 pm ] |
Looks Great!!!! You might want to consider a simple shroud for the pully..... What did your shaft speed end up to be? |
Author: | Daniel Minard [ Thu Jun 16, 2011 10:01 pm ] |
Good job! Now go get a roll of 1/4" foam tape & cover all those sharp corners you might bump into. ![]() |
Author: | Chris Ensor [ Thu Jun 16, 2011 10:25 pm ] |
Daniel, that sounds like a great idea. Where might one find such a thing? |
Author: | Chris Ensor [ Thu Jun 16, 2011 10:27 pm ] |
Robbie_McD wrote: Looks Great!!!! You might want to consider a simple shroud for the pully..... What did your shaft speed end up to be? 1000 rpm |
Author: | unkabob [ Fri Jun 17, 2011 10:27 pm ] |
I would round-off all the sharp corners with an 80 grit sanding block. I would look for foam tape in a dollar-store or use spray adhesive on polyether foam or click-floorin underlay foam. Just some cheap fixes. Bob ![]() |
Author: | Daniel Minard [ Sat Jun 18, 2011 12:34 am ] |
If you strike out at the dollar store, you can find rolls of black foam rubber (I think it's neoprene) in the door & window insulation department of any building supply store. The white stuff is cheaper, but not much good for anything. It comes in several different widths & thicknesses. I use the 1" wide & 1/4 or 3/16" thick stuff. |
Author: | TonyKarol [ Sat Jun 18, 2011 7:54 am ] |
The only thing I would have (and have done) different is mount the pillow blocks such that the part of the block that contains the bearing is pointing out (not the bolted end) - this gives you the most clearance between the buffs and the parts mounting the shaft. Other than that, its pretty much the same as mine, whcih works great. |
Author: | Daniel Minard [ Sat Jun 18, 2011 10:23 pm ] |
+1 on what Tony said. One day, I plan to do that to my own buffer, but it hasn't p'd me off enough yet to motivate me to do it. |
Author: | dnf777 [ Fri Oct 17, 2014 12:45 pm ] |
also have seen belts left intentionally loose to allow slow-down of the wheels with a little pressure (before burning through) Nice build though! |
